Dear sirs,
I have just started modelling a building in WUFI®Plus using the 3-D Editor and came across the following doubt: When defining a wall, the vertices that we input should correspond to the coordinates of the wall’s outer surface, middle or inner surface?
Thanks in advance for your help.
3-D Editor - Wall coordinates
Re: 3-D Editor - Wall coordinates
Dear jorne,
you can define this in the options of WUFI Plus. There, you can select, if the visualized geometry represents the inner or outer surface of the components.
Greetings
mwinkler
Greetings
mwinkler
