Calculation mode in WUFI PLUE V.2.5.4.0
Alina0826
Post by Alina0826 »
Hello:
When I use WUFI Plus V.2.5.4.0, the "Dialog Box" of case as follow which has no option for "calculation mode".
But this "calculation mode" can be found in WUFI Plus WIKI Guide.
How can I change the setting for "calculation mode" to "hygrothermal in WUFI Plus V.2.5.4.0?
Thank you!
mwinkler
Re: Calculation mode in WUFI PLUE V.2.5.4.0
Post by mwinkler »
Hello Alina0826,
selecting the "calculation mode" differs from WUFI Plus 2.5.4 to WUFI Plus 3.X. In WUFI Plus 3.X you can select either "hygrothermal" or "thermal" calculations from a dropdown-list, as you have seen in the WUFI Wiki. In WUFI Plus 2.5.4 hygrothermal calculations are set as default value. You have to check the "only thermal calculation" checkbox to activate thermal calculations. If this box is not activated, WUFI Plus 2.5.4 performs hygrothermal calculations.
Greetings
mwinkler
