There is a problem assigning a self made climate in the actual release. If you choose "Select user defined file" in the climate module the following error message can appear while switching to the Processing Menu: ""unassigned climate in surface conditions".
Actually there is a workaround for this problem: Save your project, close Wufi2d. Then enter the directory of your Project and open the file wufi2d.xml with an editor. Search for the String "ClimateFileNumber". Between <ClimateFileNumber> and <\ClimateFileNumber> there is a number. Change this to a positive number unequal zero (for example 21). Then save the file and reopen the project. Now it should work.
There is a second workaround for the "unassigned climate in surface condition" using a self-created climate file:
Choose a climate from the map, assign it, then click on the menu calculate. The error-message does´nt appear now. Now change back to the climate window and choose the needed climate-file. After assigning it again, you should be able to start the calculation.
Problem with user-generated climate files
