Hello
Some of our analyses takes a very long time to print.
We run WUFI Pro 5.3.4.1363.
Printing is done from Outputs-Report using PDF Xchange.
Printing time seems to increase when calculation period is longer. Why?
The graphs in my PC screen (Outputs-Report) does not take longer to display, but the print does.
Christer
Printing speed WUFI Pro 5.3
Sebastian Boegl
Re: Printing speed WUFI Pro 5.3
Hi Christer,
usually the printing driver receives the output as printable nodes instead of a picture. Hence, the printer has to process more data on an increased calculation period and takes much longer to print.
I don't know an option to change this behavior.
Sebastian
Sebastian
Hi Sebastian
OK, thanks.
Wishlist: Some kind of optimization wanted regarding the algorithm that sends print information to the printer driver.
Christer
OK, thanks.
Christer
Dear Christer,
i would recommend to use WUFI Pro 6. There you can create your own diagrams with (the more powerful) WUFI Graph and also compare the results from different cases. The printing works faster with that as well.
