Indoor Climate - User Defined 162 Mean Temperature
rrenaud
Post by rrenaud »
I am trying to use a User Defined Indoor Climate under the Sine Curves. I set the Mean Temperature at 72 degrees F with a 3 degree Amplitude. When I run the simulation it changes the indoor Mean Value to 162 degrees F and and Amplitude to 5.4 degrees F. I change it back to rerun and it changes it again.
I can't get it to run the simulation that is not a hot sauna indoor condition. What am I missing? Does anyone else have this problem?
I am running WUFI PRO V.6.0
Release 6.0.1.2024.DB.26.0.15.0
Re: Indoor Climate - User Defined 162 Mean Temperature
Hello rrenauld,
I am not sure which version you use but the free update to 5.3 should solve the problem, I just checked it. Fraunhofer IBP may support you with the download link for this.
rrenaud
Post by rrenaud »
Upgraded to 6.2....problem solved.
Thank you.
