How to setup moisture buffering in WUFI Plus
Alina0826
Post by Alina0826 »
Hello WUFI Team:
I'd like to set moisture buffering of wood truss in WUFI Plus model.
Can I know how to set the details in WUFI Plus?
Thank you!
Alina
Re: How to setup moisture buffering in WUFI Plus
Post by mpazold »
Hello Alina,
if they are not regarded in the exterior component, you might can add them as interior component with the same zone on both sides (interior and outer side) and set the surface area acording to one side, and the thickness of the component material. Its mostly not necessary to model it in the 3D visualization, you can add it as an not visualized component.
Best,
Matthias
