Climate file for subsoil
PierreC
Post by PierreC »
I would like to study the behavior of a low floor. I have the modelisation, the boundary conditions for the top surface (I use EN 15026). I also have my own boundary conditions for the subsoil on a .wac file, but I don't know how to insert this .wac file on Wufi.
Can i just import my file in the first section "Map/file" ? Because by this way, I think wufi will suppose that this is an outdoor surface : even when i fill the button "Treat as Indoor Surface", the orientation and the inclination (that I don't want to speficy because this is a horizontal indoor surface) are still waiting to be written.
Thank's a lot for your help!
Pierre
Re: Climate file for subsoil
Once you hit the the Button "Set Climate" there should be an option "User-defined" climate as a tab sheet in the very top area of the dialog popping up
