I'm attempting to model a smart vapor retarder (specifically the Intello Plus manufactured by 475 High Performance Building Supply). The product specification sheet states that the vapor retarder has a vapor variability of < 0.13 perm during dry winter conditions, and > 13.2 perm during summer conditions to increase drying potential. The DIN EN 1931 Perm rates are listed in the specification from 13.20 to <0.13 (Sd value from 0.25m to >25m). The ASTM E96 (dry cup/wet cup) values for vapor variability are 0.2 perm to 6 perm.
Working in IP units, I'm wondering how to interpret this information in order to input RH values and permeability (perm-in) so that I might be able to model this vapor retarder's behavior. I realize that this might be simple question of unit conversion, but I am hoping someone might be able to help me work through it.
Thank you for your time.
Best,
Kenner
Modeling Smart Vapor Retarder using moisture dependent permeability
- WUFI.JPG (112.9 KiB) Viewed 64860 times
Re: Modeling Smart Vapor Retarder using moisture dependent permeability
Hi Kenner,
you may have to transfer the units. See here for information about doing that, they have a nice diagram on page 4:
www.builddesk.co.uk/wp-content/uploads/ ... tances.pdf
fkbuisman
- WUFI ORNL Instructors
Hi Kenner,
INTELLO Plus is listed as a material in the North American as well as the regular Fraunhofer database.
No need to make this material yourself. use it as 1mm thick noted in the material file.
Floris
Floris
