Indoor Climate - ASHRAE 160P
serenewongsa
Post by serenewongsa »
At a WUFI class, we were informed that using ASHRAE 160P for the indoor climate is the most accurate option in WUFI 4.1. Could someone give a little crash course on all the variables that i can input in this screen? Such as the floating indor temp shift, set point for heating, moisture generation rate. Thanks.
yalinu
Post by yalinu »
The set points will depend on your design. That info usually comes from the HVAC engineer.
ASHRAE 160P gives a good methodology you can follow when doing your analysis.
For ASHRAE 160P document go to:
http://www.ashrae.org/technology/page/886
and download the PDF.
The following link is a narrative of ASHRAE 160P.
http://www.fpl.fs.fed.us/documnts/pdf20 ... lde001.pdf
Be aware that this standard is a public review draft. 160P has still not been officially published by ASHRAE.
Yalin
