W5p's from Wufi 6?
Toby Cambray
W5p's from Wufi 6?
Post by Toby Cambray »
Hello
I'm working with a colleague who is still using Wufi 5 (I'm on 6.3). Is it possible to save w5p's for him from Wufi 6? If so it is not obvious...
Toby
Re: W5p's from Wufi 6?
Dear Toby,
WUFI Pro is not compatible downwards. You can try to rename the file from .w5p to .w6p, but new functionalities will not be used in WUFI Pro 5. SO if you calculate your case again in WUFI Pro 5 you probably will get different resulted.
