output an initial condition-or-continue last calculation
yuan
Post by yuan »
I was calculating hygrothmeral behavior of the ground, and it needs a long time to heat up. So I was wondering is it possible to output the temperature distribution results at the final stage, and then input it as an initial calculation in a new calculation?
Thank you so much!
Re: output an initial condition-or-continue last calculation
Hi Yuan,
yes, thats possible.
Open the results in WUFI 2D Motion, press backspace to get to the last time step of your calculation or use Ctrl + G to go to the step to export.
Do a right-click on temperature and select extract -> initial conditions. Do that as well for the water content or relative humidity.
In WUFI 2D go to "Initial Conditions" -> "Use initial conditions from file" to import these files.
yuan
Post by yuan »
Thank you so much dear Bludau!!! that helps me a lot!
Yuan
