Simulation of absorption experiment
palino1
Post by palino1 »
i have one question about simulation of absorption experiment. I made KLI file with climate conditions according manual, it is working.
I did a one-dimensional experiment with sandstone, I have A and wcap. I would like to use WUFI to check these parameters, but if I am creating a new material, when Dws, Dww, I need Acap, wcap and water content at 0.8.
What value of water content at 0.8 used, because I do not have a measured sorption isotherm. Also, what a internal conditions should I use ?
Can you help me please ?
Re: Simulation of absorption experiment
Hi palino1,
it seems you wish to do two things:
* Create a new material whose liquid transport coefficients are "generated", using a measured A-value and a measured free saturation as input parameters
* Use this material in a simulated absorption experiment to check whether the liquid transport coefficients generated in this way reproduce the measured A-value
The first item is almost independent of w(80%), the second item is completely independent of w(80%).
The formula which WUFI uses to compute the generated liquid transport coefficients only has two parameters: the A-value and the free saturation (see the topic Reference | Material Data | Liquid Transport Coefficients in the help file). WUFI also asks for the Reference Water Content w(80%), but this parameter does not affect the shape of the resulting curve, it only determines the starting point of the curve. You can check this by entering different values for w(80%) and watching the curve diagram.
Below w(80%) the liquid transport coefficients are assumed to be zero. So your choice of w(80%) only affects the resulting curve in a minor way, in particular if w(80%) is markedly smaller than free saturation. In this case the choice of its value only affects the behavior in the region of small water contents and not the high water contents where most of the action in an absorption experiment is.
And concerning the simulated absorption experiment: The absorption of liquid water is determined by the water contents only and is independent of which relative humidities correspond to which water contents. That is, it is independent of the moisture storage function.
As an example, the following diagrams show the results of simulated absorption experiments performed on Baumberger sandstone. In the first simulation the original Baumberger moisture storage function was used, in the other two simulations arbitrarily modified moisture storage functions were used. While the profiles of relative humidity (the green curves) are different, the resulting water contents (the blue curves) are the same after identical simulation periods, and so the resulting A-values are the same as well:
So for the simulation you can use any arbitrary w(80%).
Concerning the interior conditions (the conditions acting on the side of the specimen which is not absorbing the water): The temperature should be the same throughout the specimen, so the temperatures at both surfaces should be set to the same value. The non-absorbing surface of the specimen should be made vapor-tight by applying a very large sd-value (say, 9e9 m) to prevent moisture loss by vapor diffusion through the surface. This de-couples the specimen from the humidity conditions on that side and you may use any arbitrary humidity there.
palino1
Post by palino1 »
Hello Thomas,
thank you for your answer. I understood it from your answer. Now i have question. I made my own test model in wufipro with baumberger sandstone as you.
i chose baumberger sandstone, i used original parameters from database.
I made climate KLI file according FAQ question with rain.
I set on the interior surface metal foil.
I set initially dry material and constant temperature 20°C.
But the course of wetting is different as your. I dont know why, also the maxium value of water content (210) is achieved after a long time. I upload picture with settings and course.
Also, it is possible to make this experiment in wufi 2D ?
And how i can find out, that my real experiment, where i got A,wcap with this type of simulation ?, for 1D water transport experiment i used sample with 50x50x30 mm.
Thanks for reaction.
palino1 wrote: Thu Nov 19, 2020 2:37 am -1100 But the course of wetting is different as your. I dont know why, also the maxium value of water content (210) is achieved after a long time.
Hi palino1,
it seems the problem is the setting for the "Adhering Fraction of Rain". This factor takes into account that when rain water hits a non-horizontal surface, part of the water immediately splashes off and is not available for capillary absorption. For example, for vertical surfaces typically 30 % are splashing away and only 70 % stick to the surface. This can be taken into account by entering 0.7 in this field, the rain rate read from the climate file will then be multiplied with this factor to take the reduction of available rain water into account.
The default setting is "Depending on inclination of component", and although WUFI understood that the inclination of your component is 90° (see your screenshot with the blue text), apparently this information is not properly taken into account when a KLI file is used. It seems that the "adhering fraction" is set to zero, and no water reaches the surface of the component. The slow increase of water content you see during the calculation is simply the hygroscopic uptake of water vapor from the moist ambient air.
If you select "user-defined" from the drop-down list and manually enter "1" for the adhering fraction, the simulation should run as expected.
Yes, but it is much less convenient.
I'm not sure I understand the question. If the sample was homogeneous and its surface was wetted uniformly, the absorption process is basically one-dimensional and you can simulate it with a one-dimensional calculation.
palino1
Post by palino1 »
Hello Thomas,
yes problem was in reduction of rain. Now it is working very well. Thank you for your answers.
