ASHRAE RH Limitations
Is there a way to remove the 70% RH limit on the ASHRAE indoor climate?
Re: ASHRAE RH Limitations
No, not at the moment. But we plan to allow that in future versions.
Workaround would be to generate your own climate file for indoor climate.
For creating your own climate files you can find CreateClimateFile.xlsx in the WUFI tools folder, probably here:
Code: Select all
c:\Program Files (x86)\WUFI\Tools\
