Hi, Please could you let me know what a code 145 is when I try (unsuccessfully) to open a project file. Calculations were run by a different machine under the same license, and the file is large (6.4GB) due to an absurdly long time frame. is there a way round this?
Thanks,
Matt
Code 145 error attempting to open project file
Matthew Smith
Hutton + Rostron
Re: Code 145 error attempting to open project file
Dear Matt,
this is related to storing large WUFI files over network or otehr virtual drives.
Please try the following.
1) Close WUFI
2) Edit
3) and add this line:
4) Save the vmoptions-file
5) Restart WUFI.
By the way, that should have been fixed with WUFI Pro 6.5. Please check if you are runnig the latest version:
viewtopic.php?f=32&t=997
If this not help, please contact our support directly (support @ wufi dot com).
Greetings
1) Close WUFI
2) Edit
Code: Select all
c:\Program Files (x86)\WUFI\WUFI6\wufi.vmoptionsCode: Select all
-Dde.wufi.project.USE_TEMP_DIR=true 5) Restart WUFI.
Greetings
Matthew Smith
