I just upgraded to v6.5 of WUFI Pro.
I've modeled 6-7 assemblies so far, mostly using default materials and climate data sets.
In my opinion, the results are considerably more untrustworthy than version 6.4. I'm running into plausibility issues and I often have to discard entire models. This has been happening over entirely different models, unrelated to one another.
Also, in the Assembly/Monitor Position, the option to enter moisture sources and monitor position has completely disappeared, which made me think of software bugs.
Thank you
WUFI Pro 6.5 - Bugs?
Re: WUFI Pro 6.5 - Bugs?
Dear Bonilauri,
if the calcualtion grid und thus the functionality to place the sources or monitor positions is not shown if there are layers which does not have assigned a thiicknes.
Further if you swithc the edit assembly to "table", monitor positions can not be set by clicking in the calculation grid. They have to be edited in the table.
Regarding the plausibility:
Did you check the balances after the calcualtion? Are they about the same? Otherwise you have numerical problems in your calcualtion.
Can you give an example of what does not seem plausible?
