Modeling Constant Temperature in Wall Cavity
I have wall system with 2 wythes of wood studs with an airspace in between. The studs are sheathed with gyp sheathing and stucco at the exterior and gypboard at the interior. Is there a way to model the wall so that the airspace between the studs is kept at a constant 67F and 55% RH? The airspace will be conditioned by the HVAC system. The project is in a warm climate, where summer conditions are 95F and 90%RH, so an air exchange source will not work.
