Mold index in wall layers
All about WUFI post-processing modules and add-ons
farshad83m
Post by farshad83m »
I have a question regarding WUFI® Mold Index VTT add-on and I would appreciate it if you could help me. I found that this add-on evaluate the mold index on the interior surface of the wall. However, I would like to know whether it is possible to assess mold index in wall layers, since the relative humidity and temperature would be different in different layers of the wall.
saricioglu pelin
Re: Mold index in wall layers
Post by saricioglu pelin »
hello,
Did you learn about this question ? because i wonder same as you.
In the WUFI Animation 1D the position in the construction can be selected, in WUFI Pro itself its only the interior surface which is evaluated.
Other possibility is to create an isopleth diagram in WUFI Graph for the needed position and then do a right mouse click on it Export -> WUFI VTT.
saricioglu pelin
I want to ask about WUFI VTT assessment. Firstly, Is it possible to evaulate the total assessment of a layer as means of WUFI-VTT ? (for example after 5 years assessment when we select a layer and open it in WUFI VTT, is it shows the assessment of this layer averaged result or which ? )
And when ''Other possibility is to create an isopleth diagram in WUFI Graph for the needed position and then do a right mouse click on it Export -> WUFI VTT.'' do it wufı vtt shows mould growth but when look at the initial parameters they are not true ? So, should i change the initial parameters (materail type vs) or not ?
Thank you.
The button in the WUFI Pro user interface only evaluates the interior surface.
It is also possible to evaluate single elements or a thin layer at the materials surface or even the full layer - easiest to do in WUFI Graph. Select the desired elements WUFI Graph and generate an isopleth diagram - WUFI Graph will mean them up. Then do a right click and select export -> open in VTT-Mould.
Please note that for most materials there is a moisture gradient over the thickness of material, and the critical position is only on one side. In this case you will get less severe conditions by building an average over the full layer.
The start conditions are exported from WUFI, what do you mean by "not true"?
