Hi there. I am a new WUFI user. I'm looking at different retrofit options for an existing building. I would like to plot the results from different cases (for example different insulation types) for a particular layer of the wall, all on the same graph. So for example in a cavity wall I want to plot the relative humidity for the outer brick layer without insulation, with mineral wool insulation and with EPS insulation. I can see how to plot the results from different layers of the same case on the same graph, but not how to plot results from different cases. Is it possible?
Thanks in advance for your help.
Es
WUFI graph - plotting results from different cases on the same chart
EsTresidder
Re: WUFI graph - plotting results from different cases on the same chart
Dear Es,
that can be done with WUFI Graph.
See the WUFI Pro Program Tour - this includes also a short introduction in WUFI Graph.
https://www.youtube.com/watch?v=IERK-a_HsEg&t=1455s
You also can compare multiple project files if you open them in WUFI Graph.
EsTresidder
Hi Christian, Many thanks, I'll look at how to do this tomorrow.
