Hello everyone,
İ am very new in WUFI. And so i have a lot of problems about exporting my draw from Autocad into WUFI 2D...i can not understand what problem is it...Because i draw all lines as polyline and also save as dxf. but WUFI can not seen ...why? please answer me..
DXF-Import (was Exporting raw data from WUFI 2D)
saricioglu pelin
Johannes Amos
Re: Exporting raw data from WUFI 2D
when you draw your construcion make sure you use closed polyline rectangles only. If the rectangle is not closed, the angle is not 90° or your construction shows other geometric shapes it cannot be imported. I use mostly the rectangle function in AutoCAD for this purpose and save my file as AutoCAD 2018 DXF.
There is also a tutorial how to import a .dxf file here:
https://wufi.de/en/service/downloads/
Also there is an example file in your installation path you can have a look at for better understanding. The path usually is:
C:\Program Files (x86)\WUFI\Tools\DXF2WUFI\sockel.dxf
Hope that helped.
Johannes
Hope that helped.
Johannes
Re: DXF-Import (was Exporting raw data from WUFI 2D)
Note: I split the topic to a new one as it was not related to the topic where it was created first.
