This applies to using IP-units only
When one inserts a material from the material database, if the perm-in value is very low (below 0.001) at RH=0 then the number gets deleted and it has to be re-entered before running the case. Looks like the format in IP-units does not keep the significant digits. This does not seem to happen when the units are SI.
