WUFI-Graph not working
jacques.l
Post by jacques.l »
Until now, I never had a problem opening WUFI-Graph from a WUFI Pro project file, but yesterday I received an error message asking me to install Java on my computer, which I did. Since then, the results of the simulations do not open in WUFI-Graph (completely empty window) and I cannot open them by myself because no results file is created when I run a WUFI simulation. (I checked, 'Film data' is checked in Options > Result Data)
Any idea where the problem might come from?
Thank you in advance for your help.
Lionel
Re: WUFI-Graph not working
Hello Lionel,
normally WUFI includes a java distribution, which may have been damaged somehow.
I would try to reinstall WUFI, that should fix both issues. I guess the problem is not WUFI itself, as there should be a message, if no result data is contained in the file, you want to evaluate.
jacques.l
Post by jacques.l »
Thank you very much Christian!
It's now working again.
