Installation of VTT
Installation of VTT
I'm using WUFI Passive/Plus and need to use VTT. However after I install VTT it does not become available as a post-processor. I've checked wufi.ini and it seems to point to the correct place. Any help would be appreciated.
Re: Installation of VTT
WUFI VTT or WUFI Bio should be displayed in the Film viewer (take a look at the help topic Assessing the results)
Thanks, Sebastian. That's where I was looking. I presume VTT should show up as a button like WUFI Bio typically should. Although after installing Bio I stil don't see either in the extended animation window.
Also, WUFI Bio doesn't show up anymore either.
Do you have any luck showing the post processors by clicking on the right button named "Extended animation"?
No, it's not there. Once I open the extended animation, which opens WUFI Animation 1D, I don't see Bio nor VTT buttons on top menu bar as expected. But both Bio and VTT have been installed.
Please try the following to get this working:
- Append the following to the file %PROGRAMDATA%\WUFI\wufi.ini:
If you are unable to save the changes to the file, save it under a different name such as wufi-new.ini, delete the old wufi.ini and rename the file to wufi.ini.
Code: Select all
[WUFI6] PostProcessorPath=C:\Program Files (x86)\WUFI\PostProc\
- In order to run the Postprocessors download and install the latest WUFI-JRE from here.
Thank you!
I installed WUFI-JRE64 and added that bit of code to wufi.ini. That seemed to have worked.
I have this exact same problem. Would it be possible to explain a bit further how to do this? For instance where do I find this file:%PROGRAMDATA%\WUFI\wufi.ini? and how exactly do I append it?
OK, I figured it out. Sorry I'm not a Windows user so it took me a while!
