Keep ASCII Export Data Selection after re-calculation
PScharfA
Post by PScharfA »
Hello all,
is it possible to keep the selection of the courses and profiles in the ASCII Results export?
Unfortunately, the selection is reset (no boxes checked) after each calculation and a manual re-selection is required. This would help speed up the process in multi-variant sensitivity analysis and excel based post-processing :)
Thank you for your help,
Philipp
Re: Keep ASCII Export Data Selection after re-calculation
Hi Philipp,
that is not possible in the actual version.
You could change the case in WUFI and then calculate it via command line. There you could define the output using the -v option.
See also here: https://www.wufi-forum.com/viewtopic.ph ... atch#p2168 and the WUFI program help topic batch.
