How can I create a transparent material - glass in pro 6.7? I need to develop a calculation for a double skin facade with a glazed outer pane.
BR,
Andris
Transparent material
Re: Transparent material
Hi Andris,
you can model the glass itself as a tight layer (e.g. vapor barrier) or better assume it as an sd-value in the boundary condition. Then you could use a heat source to release the radiation at the position where the radiation occurs. The heat source can be defined as percentage of solar radiation.
