Dear all
20% moisture content is a typical value to use when assessing wood rot.
But wood that has been protected using chemicals will presumably allow increased moisture content before the onset of rot.
I can't find any information online to suggest a suitable moisture content to use when assessing treated wood.
Has anyone looked into this before please?
Thank you
David
Wood rot threshold for chemically-treated wood
Re: Wood rot threshold for chemically-treated wood
Hi David,
I'm not aware of any limit values for treated would in standards. Normally the information is more like: if you exceed the normal limit value you need chemical protection.
However, 20 % is pretty conservative. The WTA guideline 6-8 allows clearly higher values depending on the temperature (at 0°C for example up to 26 %). Maybe it helps more to use such temperature dependent or even transient limit models. Our rot predicition post processore will also be available next year.
best regards
best regards
Thanks Daniel
Looking forwards to the rot tool.
