Last week, I made some simulations with WUFI PRO 7, I saved the file and closed WUFI PRO 7.
I opened Wufi Graph and open the wufi results saved through Wufi Graph.
I created some pages and datas I wanted to visualise, then I saved the Wufi graph project, and closed Wufigraph.
Today, I want to open the wufigraph file to add some datas, and I had an error message (in french): "results file not available, operation don't handled)...
I had make no change on the wufi pro file, and I lost the link between wufi pro file and wufigraph...
Even with "update" button, the link is lost...
I also have exactly the same issue with WUFI2D simulation...
Is there a possibility to "repare" the link from wufigraph to the wufi pro file?
How I have to do to don't have such issues?
Thank you for your replies
WufiGraph lose link with wufi results
Re: WufiGraph lose link with wufi results
Hi Thomas,
if the file is not found, it should be colored in red in the result file window. If you click on it a window opens, which allows to set a new path for the result fie.
Dear Christian,
Actually, it is not colored in red. It is grey and I cannot change or add anything after closed the original one.
(I also write a message for this problem in WUFI PRO index, in response on a message with the same problem)
Thank you for your support
Hi Thomas,
is this related to results from WUFI Pro 6 or 7?
Which version of WUFI Graph do you use?
Dear Chrsitian,
Results from WUFI 7.2 and
Thomas and WUFIGraph 2.29.6
Hi Tom,
I can reproduce that on one of my computers, but not on an other. We have to fix that somehow.
There is a workaround to reconnect the file. Rename the w7p-file or change the path before loading WUFI Graph - then it will show you the file as missing and by clicking on it, you can select the renamed file. This way it loads as it should.
Sorry for the inconvenience, we are on fixing that.
