What does "Moisture-dependent" of μ-value mean exactly?
Does "Relative humidity" means surround of the material ?
Or, inside of the material?
Water Vapour Diffusion Resistance Factor, Moisture-dependent
Re: Water Vapour Diffusion Resistance Factor, Moisture-depen
It means that the µ value depends on the moisture content. This is in the most cases physically not really correct, but helps to model some specific materials (e.g. wooden materials, polymere materials).shinya wrote:Hello,
Both, because dead end pores in moisture storing material are very seldom.shinya wrote: Does "Relative humidity" means surround of the material ?
Enjoy WUFI®
.... It is easy and complex.
Enjoy WUFI®
