rising damp in basement wall approach has changed?
Post by Alberto Morales »
Has the approach to simulate the effect of rising damp changed?
what I do is (starting point. the WUFI basement example of the "Handling of typical construction in WUFI"):
1- export T and RH from the sinusoidal curve
2- in "create climate" excel file, I add a new column RM (measured rain) and I set as 1000
3- I import this .wac in wufi as external climate
combined-image (2).jpg (346.73 KiB) Viewed 328 times
Case "without ground water"...interior and "exterior" climates the same than in the default case for basement from "Handling of typical construction in WUFI"
Case "with ground water"...I set the new climate just adding that measure rain from the "base case"
why is the water content I get in the concrete and insulation layers is pretty similar for both cases? I expected higher WC for the second case as I added a constant source of water in the soil. Although the WC in the materials for both cases are increasing constantly and not reaching steady-state.
Any thoughts? I have tried to follow all steps explained in the pdf of "Handling of typical construction in WUFI" for the basement case.
if I set to 1 the "RAIN PARAMETER" for the case "with ground water", the results do not change.
Last edited by Alberto Morales on Fri Nov 20, 2026 4:27 am -1100, edited 2 times in total.
Re: rising damp in basement wall approach has changed?
and the soil material, in which the measured rain has been added, dries...instead of being saturated
