How to set inner climate
Hiroki Ogata
Post by Hiroki Ogata »
I tried to simulate inner climate by Wufi Plus. I set minimum temperature and maximum temperature and also air conditioning such as heating power. But, a result of Wufi Plus showed that simulated inner temperature was minimum temperature set by me. I expected that inner temperature changed with outdoor climate between minimum temperature and maximum temperature set by me. How should I set conditions.
Thank you very much for your suggestions.
Kristin
Design inner conditions
Post by Kristin »
How do you define the air conditioning, at which points in the software tree? Because only at the optional climate you can define a air conditioning over a check box, but this is the outdoor climate to the components which you define.
To design the air conditioning for the inner climate is possible over the min. and max. temperature and additional you have to define the heating and cooling power at the equipment.
The easiest way to find out what´s going wrong is if you send me the WUFI-Data.
Hiroki Ogata
Re: Design inner conditions
Thank you for your reply, but how can I sen you my WUFI-Data?
Hiroki Ogata
Kristin wrote:How do you define the air conditioning, at which points in the software tree? Because only at the optional climate you can define a air conditioning over a check box, but this is the outdoor climate to the components which you define.
