Simulating unventilated cold roof
Francisco
Post by Francisco »
I need to simulate an unventilated pitched cold roof, but I am not sure how to simulate the loft space. Can this inhabitable big space be simulated like a normal air cavity?
David Lam
Re: Simulating unventilated cold roof
Post by David Lam »
I've also been asked to look at a cold roof situation to determine the amount of ventilation needed.
Is there any guidance on doing this in WUFI please?
Hi David,
please have a look in our download section:
https://wufi.de/en/service/downloads/
Start over with the "Handling of typical constructions":
https://wufi.de/en/service/downloads/#t ... structions
In the list there are also more specific tutorials about different roof types.
David Lam
Post by David Lam »
Hi Christian
That is very helpful thank you.
However I'm looking at this sort of build-up which is not in the guidelines you have linked to.
Do you think WUFI is an appropriate tool for this? Image is from EN 5250
Figure 54 from EN 5250
Figure 54 from EN 5250.png (102.19 KiB) Viewed 72016 times
Thank you
D
Hi David,
the attic space itself can not expressed in WUFI as an air layer, as there will be a significant influence of the convection.
We set up models to derive the interior climate from the outside conditions for unheated attic spaces, but this is only available in German at the moment. Maybe you can use some online translation tool.
Here you can find a summary of the models:
https://wufi.de/de/wp-content/uploads/sites/9/555.pdf
and this is the full research report where the models where developed:
https://wufi.de/literatur/Zirkelbach,%2 ... gungen.pdf
Another way would be to model the attic space in WUFI Plus and calculate the attic space climate conditions which then can be used as boundary conditions for WUFI Pro or 2D.
David Lam
Post by David Lam »
Thanks Christian
l.clapham
Post by l.clapham »
Hi Christian,
Please could you suggest how to modify the climate file as suggested in the model summary you attached. In particular, how would you modify the climate file to add 0.5 g/m3 of moisture to each datapoint?
Is there a way to do it in WUFI? We have tried to edit to a HRY file directly but we are unable to open it without WUFI.
Thanks in advance,
Laura
Hi Laura,
the models are included in WUFI Pro 7 in the user-defined climate tab of the interior climate.
There select the needed attic model from the template pull down.
The RH is derived as a additional moisture load depending on the outdoor humidity.
In here you can rise the values of the additional moisture load for the indoor RH by the needed value.
