Move of Wufi23 files
Michel
Post by Michel »
Hello
I use Wufi2d3.3.
I changed recently my PC and kept in parallel my old hard disc where my first version of Wufi2d3.3 was located and I can still open my Wufi files on this old hard disc.
I reloaded Wufi2d3.3 on my new PC and it works well.
Unfortunately I am not able to load my previous files in the old hard disc.
From Wufi 2d3.3 in my new PC , I cannot access my old files in the old Hard disc as the window "Open project" is too limited.
I have moved manually my old files from the old hard disc to the new file "Project" of Wufi2d3.3 in my new PC. However, when I click"Open project", they do not appear.
In addition when I close the software, a window appears "Run time error 216 at 00404616"
veitner
Post by veitner »
Dear Michel,
to change the default project root directory select Options/Settings from the menu and point the entry "Home Directory" to the desired position.
The runtime error 216 is caused by the help system using Windows Vista or Windows 7 only. This error is fixed with the latest version of WUFI2D. I will send you the link for the update by email.
