Rain shield between two layers
Raymond
Post by Raymond »
How to represent a rain shield wich is not located on the outer surface but between two layers of materials
We think proceed as that :
- We will use the same method as for vapor retarders to determine an effective menbrane.
- We don't know the heat capacity (we wait a manufacturer answer) we think use a heat capacity of 1500 J/kg.K (as for organic materials) is appropriate as a first approximation.
The use of zero values for liquid transport coefficients is it sufficient to represent the rain shield ?
Thanking you by advance.
Greetings.
Hello Raymond,
I think you approach is OK.
The exact heat capacity for a 1 mm thick layer is not important.
