WUFI 2D: Could not find database
roberto
Post by roberto »
Hi!
I just installed WUFI2D-3 but got the above error message when starting WUFI 2D. Have you any idea what went wrong?
BTW, the "Install_WUFI-DB.exe" was executed normally during the istallation.
Do you use Windows 7?
Did you run the installation with administrative privileges?
Do you have read/write privileges (for current user) in directories "IBP-Software/Database" (MSAccess wants to create a *.ldb file) "IBP-Software/Tools" (for update of wufigraph.xml)
You also should give read/write privilegs to the whole folder IBP-Software/Wufi2D-3
roberto
Post by roberto »
Thank you for your quick reply, Christian! Unfortunately I have still the problem.
I am using Windows XP Professional Version 2002, Service Pack 3. And I have administrator rights to the computer.
In C:\Program Files\IBP-Software\Tools I cannot find any *.ldb -files.
I also have WUFI 5.1 Pro in C:\Program Files\IBP-Software. It works well.
veitner
Database not found
Post by veitner »
You got a PM
roberto
Post by roberto »
Thank You very much, veitner! Problem solved
xavdeq
Re: WUFI 2D: Could not find database
Post by xavdeq »
roberto wrote:Hi!
BTW, the "Install_WUFI-DB.exe" was executed normally during the installation.
same problem here with WUFI 2D 3.3 on Windows XP /on MAC/Parallels Desktop
user = admin
I do not know how to eventually set privileges
no .ldb file
veitner
Post by veitner »
Hi xavdeq,
you could try to add following section to the file
%AppData%\\WUFI2D-3.3.ini (type %AppData% as "location" in WindowsExplorer)
[Climate]
Database=c:\Program Files\IBP-Software\Database\IBP_24.mdb
Veit
xavdeq
Post by xavdeq »
veitner wrote:Hi xavdeq,
[Climate]
Thank you very much, this worked.
(remember that you assumed I use an English version of WinDOS)
