EIFS Drainage Plane
pgphillips
EIFS Drainage Plane
Post by pgphillips »
I am trying to model a drainage plane with an air layer just outside the WRB. Is there anything I need to do as far as sources and sinks in the air layer. Should I use something different from the "air layer" material?
I added 1% rain leakage in the WRB; is that the right approach?
Thanks in advance.
Paul Phillips
Dear Paul,
just use the air layer and an appropriate average air change rate.
The 1% Rain source might cause stability problems. In this case place the source at the OSB/Plywood behind the WRB
