Switching WUFI between different languages
Greetings to all WUFI users,
this is just a note to point out the language tool "WUFI_Lan.exe" which is distributed with WUFI 4.0 (see "Tools" folder).
The application file WUFI.exe itself is now language-independent; the text strings are read from language files. By default, WUFI will use the language selected by the user for the installation. However, the user can change the language at any time by running WUFI_Lan.exe and selecting the desired language: German, English, Finnish, French or Norwegian. This will change all the text of the user interface and the database.
The language of the help file, however, will not be changed, and the file type names registered with Windows will also remain the same.
You must have administrator privileges to run this tool.
Bye,
