Standing Seam Roofing
DavidHughes
Post by DavidHughes »
Hi again from the course notes specifically Manfred's presentation, slide 20, showing the test built standing seam roof "Effects of Moisture and Hugrothermal Peformances Evaluation in Building Practice" the example illustrates vapour being driven back and forth as night conditions change to daytime conditions.
I am trying to model such a roof to determine whether it needs to be ventilated behind the metal sheeting or not and if so to what extent.
There is no data on standing seam roofing in the database but in the Surface Transfer Coefficients there is an Sd Value of 50 for 'Aluminium Siding (incl. rebate) sic)
So my question is should I omit the metal sheeting and use this Sd value for the metal roofing and set the rain adhesion to zero or else to no adhesion and the value of 1?
Thanks again
Hello David,
yes, use "Aluminium Siding (incl. rebate)" with an sd value of 50 m for the exterior transfer coefficient and set the rain adhesion to zero.
