Reading data from WFD files
Bakonyi Daniel
Post by Bakonyi Daniel »
I am using Matlab as a post processor for WUFI2D, so I nedd to export raw data from the naetive .wfd file. Untill now I've been trying to use the java code you posted to get the data (http://www.wufi-forum.com/viewtopic.php?t=556), but now I encountered problems. The RH data I export is damaged: the rows get mixed together. I also had problems compiling the java code in the frist place.
Could you send me a newer version of the java code, or help me fix mine?
Bakonyi Dániel
veitner
Post by veitner »
what do you mean with 'mixed'?
There is no newer version right now.
But there is a tiny sample (IntelliJ Project) for download at:
WUFI2D-FileData.tgz
and some java doc:
doc.tar.gz
and here comes another sample (paste it to a file named 'Gui.java':
<file Gui.java>
package main;
import main.core.data.IGrid;
import main.core.data.IMaterial;
import main.core.data.IWufiData;
import main.core.data.constants.OneArrayResults;
import main.core.data.dt.primitives.MyPoint;
import main.core.data.factory.WufiDataFactory;
import javax.swing.*;
import javax.swing.filechooser.FileFilter;
import java.awt.*;
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
import java.io.File;
import java.io.IOException;
import java.util.HashMap;
import java.util.Map;
* @author veitner
* Date: Nov 14, 2011
* Time: 10:03:05 AM
* $Id: Gui.java $
public class Gui extends JFrame {
private void printLayout(IGrid g, java.util.List<IMaterial> mat,
StringBuffer sb) {
sb.append("Materialclassification (0 is unassigned or a boundary
if next neighbour !=0):\n");
for (int j = 0; j < g.getGridLayoutY().size(); j++) {
for (int i = 0; i < g.getGridLayoutX().size(); i++) {
IMaterial m = g.getGridElement(i, j).getMaterial();
int id = (m == null ? 0 : mat.indexOf(m) + 1);
sb.append(id).append(" ");
sb.append("\n");
sb.append("\n");
private void printData(String id, float[][] data, StringBuffer sb) {
sb.append(id).append("=(");
for (int i = 0; i < data.length; i++) {
sb.append("(");
for (int j = 0; j < data.length; j++) {
sb.append(data[j]);
if (j < data.length - 1) {
sb.append(",");
sb.append(")");
if (i < data.length - 1) {
sb.append(",");
sb.append(")\t");
public Gui() {
super("sample");
JPanel p = new JPanel();
final JTextField te = new JTextField();
te.setMinimumSize(new Dimension(180, (int)
te.getPreferredSize().getHeight() + 4));
te.setSize(te.getMinimumSize());
te.setPreferredSize(te.getMinimumSize());
p.add(te, BorderLayout.NORTH);
final JTextArea ta = new JTextArea();
ta.setEditable(false);
JScrollPane sp = new JScrollPane(ta);
sp.setMinimumSize(new Dimension(250, 220));
sp.setPreferredSize(sp.getMinimumSize());
add(sp, BorderLayout.CENTER);
JButton btn = new JButton("...");
btn.addActionListener(new ActionListener() {
public void actionPerformed(ActionEvent e) {
JFileChooser fc = new JFileChooser();
fc.setFileFilter(new FileFilter() {
@Override
public boolean accept(File f) {
if (f.isDirectory()) return true;
String s = f.getAbsolutePath();
return s.toLowerCase().endsWith("wfd");
@Override
public String getDescription() {
return "*.wfd|*.wfd";
if (fc.showOpenDialog(null) ==
JFileChooser.APPROVE_OPTION) {
StringBuffer sb = new StringBuffer();
te.setText(fc.getSelectedFile().getName());
WufiDataFactory wdf = new WufiDataFactory();
try {
IWufiData wd =
wdf.getWufiData(fc.getSelectedFile());
IGrid g = wd.getGrid();
sb.append("Grid:\nx=(");
java.util.List<Float> l = g.getGridLayoutX();
for (int i = 0; i < l.size() - 1; i++) {
sb.append(l.get(i)).append(",");
sb.append(l.get(l.size() - 1)).append(")\n");
sb.append("y=(");
l = g.getGridLayoutY();
sb.append(l.get(l.size() - 1)).append(")\n\n");
printLayout(g, wd.getMaterials(), sb);
Map<Enum, float[][]> temp = new HashMap<Enum,
float[][]>();
int x = 1;
int y = 1;
while (g.getGridElement(x, y).getMaterial() ==
null) { //find a non null element
x++;
MyPoint pos = new MyPoint(x, y, x + 1, y +
1); //select 4 elements
/*either this and iterate through the data
HashSet<MyPoint> hsPos = new HashSet<MyPoint>();
hsPos.add(pos);
ICalculationResult cr =
wd.getCalculationResults(OneArrayResults.ksTeta,hsPos,wd.getCalcInfo().getStartDate(), wd.getCalcInfo().getEndDate());
or that*/
sb.append("some Data:\n");
for (long step = 0; step < 5/*maxSteps*/; step
sb.append("Step:
").append(step).append("\n");
if
(wd.getCalcInfo().getResultOptions().get(OneArrayResults.ksTeta))
{ //temperature
wd.getResultElements(OneArrayResults.ksTeta, step, pos,
temp); //retrieve the data
if
(wd.getCalcInfo().getResultOptions().get(OneArrayResults.ksRH)) { //rel.
humidity
wd.getResultElements(OneArrayResults.ksRH, step, pos, temp); //retrieve
the data
if
(wd.getCalcInfo().getResultOptions().get(OneArrayResults.ksWC)) {//
water content
wd.getResultElements(OneArrayResults.ksWC, step, pos, temp); //retrieve
the data
if
(wd.getCalcInfo().getResultOptions().get(OneArrayResults.ksPd))
{//partial press of vapour
wd.getResultElements(OneArrayResults.ksPd, step, pos, temp); //retrieve
the data
float[][] d;
if
(temp.containsKey(OneArrayResults.ksTeta)) {
d = temp.get(OneArrayResults.ksTeta);
printData("teta", d, sb);
if (temp.containsKey(OneArrayResults.ksRH))
d = temp.get(OneArrayResults.ksRH);
printData("rh", d, sb);
if (temp.containsKey(OneArrayResults.ksWC))
d = temp.get(OneArrayResults.ksWC);
printData("wc", d, sb);
if (temp.containsKey(OneArrayResults.ksPd))
d = temp.get(OneArrayResults.ksPd);
printData("pd", d, sb);
sb.append("\n");
ta.setText(sb.toString());
} catch (IOException e1) {
e1.printStackTrace();
p.add(btn, BorderLayout.EAST);
add(p, BorderLayout.NORTH);
JButton btn1 = new JButton("Close");
btn1.addActionListener(new ActionListener() {
System.exit(0);
add(btn1, BorderLayout.SOUTH);
pack();
public static void main(String[] args) {
Gui gui = new Gui();
gui.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
Rectangle r = gui.getBounds();
Dimension d = Toolkit.getDefaultToolkit().getScreenSize();
r.translate((d.width - r.width) / 2, (d.height - r.height) / 2);
gui.setBounds(r);
gui.setVisible(true);
Veit
hmsalonv
Re: Reading data from WFD files
Post by hmsalonv »
Thank you for the piece of code. I was able to get it working and it is a good start for me. However, I am not very familiar with java in general and the commands to retrieve and print data from wfd-files to other file formats. Could you possibly provide the lines of code to extract for example all Temps and RHs for all node points at all timesteps and how to output that to a file? I am looking for outputting data in a format like for example x,y,t,rh for a given time for all nodes.
Thanks,
Mikael
Hello Mikael,
you can do that for T, RH and WC by just using WufiMotion. Right click on the time step, then export...
