Hello
I'm having some issues regarding RH results. When I run my simulation, RH stops writing after some time (about a month or so) when I try to simulate a whole year. From some other threads, this seems to be because WUFI writes zeroes in the result file.
I get no error messages, and I've tried to adjust the grid from fine to coarse. When I disable "Moisture transport Calculation", RH is constant as defined by initial condistions (as is to be expected, I guess). Temperature simulations a running fine, except reaching over 100 degrees C for some reason.
Got any tips to solve this problem?
Thanx =)
Relative Humidity issues
Hello Krisba,
please check if this is helpful:
http://www.wufi-forum.com/viewtopic.php?t=439
