Could anyone give be some guidance on how to simulate a cavity wall which has been retrofitted with insulation? I have already run an assembly with a moisture source through the exterior with a 1% driving rain factor but i'm seeing little difference when the moisture source isn't present.
Any help would be grateful
Claire
Retrofit cavity insulation
There is definitely rain for my climate, its an area in the lake district, UK, which has the most rainfall per year. My assembly consists of:
-Acrylic stucco (moisture source)
-Solid brick masonry (moisture source)
-Insulation
-Concrete block
-Lime plaster
-Gypsum plaster
Should i increase the moisture content of each of the materials as they would have already experienced many years of rain penetration?
Claire
-Insulation
-Concrete block
-Lime plaster
-Gypsum plaster
Claire
