KLI FILE
carrieshaw9@hotmail.co.uk
KLI FILE
Post by carrieshaw9@hotmail.co.uk »
Hi, ive created a climate file with 5 weather variables ; diffuse radiation, solar radiation, temperature, relative humidity and rainfall in excel and with 8760 rows. how do i now turn this into a kli file so that it is compatible with wufi??????? thanks
carrie
Hello Carrie,
in your installation folder of Wufi (usually C:\PÜrogram Files\IBP-Software\) you find a folder "tools". In there is an excel-sheet "CreateClimateFile.xls". Use this one. You can generate a wac or a kli file...
ok thanks ive doune that and clicked export to WAC file but it keeps coming up with run tim error 75 and i have no idea what ive done wrong!!!!
Please check, if you have macros enabled in Excel...
right ive managed to convert and save it as a wac file now but when i browse on wufi to try and import it it says incorrect numeric input...what does this mean??
Can you please open the kli-file with an editor and post the first 20 lines. Use the code button at the beginning and end for that...
Thanx,
im really sorry im awful with computers and have no idea how to do what you just said!! can i send you my WAC file and see if you can see anything numerically wrong with it?? i really appreciate your help thanks! :)
I sent you a pm...
Hello Carrie,
reopen the CreateClimateFile.xls
In Air Humidity you inserted values in percent, but used [0...1]. Please change that and export again...
ok ive changed it to percent but now it wont let me click on the convert to wac button..it just doesnt do anything when i click on it :/
never mind its worked yay thanks so much!! :)
ines othmen
Re: KLI FILE
Post by ines othmen »
I need to use the kli file with a time step of 0.42 h (equivalent to 1500 s) to fit the experimental time step conditionds.
So how should I do ? I tried several times but I always obtained an error message saying "time not in ascending order in line 1" .Also how should I do to use only the start time ? My last question is which time step must be entered, will it be 1500 s
Thank you
Yours
ines othmen
Re: KLI FILE
Hello
Ineed your help please. I created my KLI file with a time step of 60s that I put in hours but no file is created.
If the time step is not regular is that could avoid the creation of the file please. THANK YOU FOR YOUR ANSWERS
Re: KLI FILE
Hello Ines,
for the kli file you have to enter hours in the first col. So if you have 60sec, the values should be 0.02, 0.04 etc.
If you did so, please post the first lines of your kli-File or xls file.
james bertram
Re: KLI FILE
Post by james bertram »
Guten morgen Fraunhofer people :)
I have been using a kli file to simulate wall performance using fire test data.
The test runs for 20 minutes and records temp at 5 second intervals.
A couple of questions please:
1 KLI file inputs - is the time sequence 0.00, 0.05.....0.55, 0.60 etc or 0.55, 1.00, 1.05 etc?
2 Under "Calc Period / Profiles", for "Time step [1h]" - is 0.05 correct for the 5 second step in the recorded data?
3 Under "Start & End Profiles" - do I adjust the number of hours to match the number of 5 second steps?
As always, thank you for your support.
James
