Laquer between two items
JSH
Post by JSH »
Hi
I have a construction where a piece of laquered wood is sitting next to another item (both right next to and with a distance of 5 mm), how would you suggest that I make the laquer, of which i know the sd-value?
Thank you in advance!
You can take the laquer in account by using a surface sd-value in the dialog surface/climate. Please not, that the rain is not affected by that sd-value, so you must switch it off (rain reduction factor = 0; in the same dialog).
JSH
Post by JSH »
Hi Christian
Thanks for the very fast reply. I have used the surface sd-value on the laquered surfaces which face outwards. But here it is in between two elements. Here i cannot add a surface condition, correct?
Thats correct... in this case you have to insert a layer with the properties of your laquer. If there are no capillary properties, just use a vapour barrier and change the µ-value. Please use no layers thinner than one millimeter.
JSH
Post by JSH »
Allright. From another thread in here I have:
"You must therefore adjust the mu value ("résistance à la diffusion de vapeur") in order to have a Sd of 18m:
Sd=mu*thickness => mu=18m/0,001m=18000"
And as my laquer would then be 1 mm thick, and my laquer has sd = 3m, I have:
mu = 3/0,001m = 3000
I'll try that :) Thanks!
Thats the right way...
