Laquer between two items
Posted: Wed Apr 11, 2012 11:52 pm -1100
by JSH
Hi
I have a construction where a piece of laquered wood is sitting next to another item (both right next to and with a distance of 5 mm), how would you suggest that I make the laquer, of which i know the sd-value?
Thank you in advance!
Posted: Thu Apr 12, 2012 12:22 am -1100
You can take the laquer in account by using a surface sd-value in the dialog surface/climate. Please not, that the rain is not affected by that sd-value, so you must switch it off (rain reduction factor = 0; in the same dialog).
Posted: Thu Apr 12, 2012 12:25 am -1100
by JSH
Hi Christian
Thanks for the very fast reply. I have used the surface sd-value on the laquered surfaces which face outwards. But here it is in between two elements. Here i cannot add a surface condition, correct?
Posted: Thu Apr 12, 2012 12:37 am -1100
Thats correct... in this case you have to insert a layer with the properties of your laquer. If there are no capillary properties, just use a vapour barrier and change the µ-value. Please use no layers thinner than one millimeter.
Posted: Thu Apr 12, 2012 12:44 am -1100
by JSH
Allright. From another thread in here I have:
"You must therefore adjust the mu value ("résistance à la diffusion de vapeur") in order to have a Sd of 18m:
Sd=mu*thickness => mu=18m/0,001m=18000"
And as my laquer would then be 1 mm thick, and my laquer has sd = 3m, I have:
mu = 3/0,001m = 3000
I'll try that
Thanks!
Posted: Thu Apr 12, 2012 12:47 am -1100
Thats the right way...
