Klimasan-Perlit : anorgische Putz
Bruno Deraedt
Post by Bruno Deraedt »
I am testing some internal insulations for a renovation of a Monument. I 'd like to use the Klimasan-Perlit plaster.
Has someone more data for puting into WUFI ?
The website says : Wasseraufnahmekoeffizient >3kg/m2 h0,5
How do you put that into Moisture storage function ? (the unit differs)
thanks
bruno
Hello Bruno,
the Wasseraufnahmekoeffizient is the a-value, you can not transfer it into the moisture storage function. It can be used to approximate the transport coefficints. To generate the moisture storage function you will need the water content at 80% RH and the saturated water content.
See the "Climatic Plaster" in the Masea Source, maybe it is similar to your one.
