Calculation Period/Profiles
Helga Kuhlmann
Post by Helga Kuhlmann »
The Calculation Period/ Profiles window in WUFI Pro 4.0 does not give the option of time. It only allows to specify a date and not the time .
Under the Output profiles, I only get the profiles at time 0 (mid night). The same happens when I want to use the option ASCII export . It only has the profile for the given day at midnight.
I want to see profiles at 2 PM, 3 PM, 4 PM etc . How can I get the temperature profile through the wall for a given day and time using WUFI Pro 4.0?
Re: Calculation Period/Profiles
Dear Helga,
nice to have you in the forum.
Helga Kuhlmann wrote:The Calculation Period/ Profiles window in WUFI Pro 4.0 does not give the option of time. It only allows to specify a date and not the time .
Yes, this is mostly not of interest.
Helga Kuhlmann wrote:Under the Output profiles, I only get the profiles at time 0 (mid night). The same happens when I want to use the option ASCII export . It only has the profile for the given day at midnight.
In the Animation1D ( the new WUFI-Film) you can navigate to every time point and investigate the results. If you press the right mouse button, you will come to a pop up menu which allows you to export the profile. Please look to the Online Help System for further information.
Regards from Bavaria,
