Trass-Lime heat insulation plaster
Talev
Post by Talev »
Dear WUFI users,
I would be ver grateful, if some of you could tell more about trass-lime heat insulation plater (fom MASEA databese catalog).
1. Can be used as an indoor insulation materials?
2. Which compnay poduce it?
3. Is there any catalog for this material?
Many thanks in advance
Talev
Re: Trass-Lime heat insulation plaster
Dear Talev,
the MASEA material data have been taken from the MASEA-ENSAN database:
http://www.masea-ensan.de/
In particular, the trass-lime heat insulation plaster is here:
http://www.masea-ensan.de/cgi-bin/viewm ... mmputz.xml
This is all we know about this material, and we can not tell you anything beyond this. The notes in that database say
* Trasskalkwärmedämmputz maschinengemischt
(trass-lime heat insulation plaster, machine-mixed)
* als Kompressenputz zur Salzsanierung geeignet
(suitable for salt rehabilitation measures)
* im Innen und Außenbereich einsetzbar
(suitable for interior and exterior use)
The data sheet lists "TUBAG" as the manufacturer, which would probably be
http://www.tubag.de/de/home.html (German website)
http://www.quick-mix.com/en/home.html (English website)
