Viewing the WUFI results via WUFI2DMotions works very well.
But I can´t see the results via WUFIGraph.
I just installed the new Java-Version but there´s still no reaction when
I push the "WUFIGraph"-button. (And I can´t find any .wfd-file in my
project folder.)
WUFIGraph doesn´t work
Re: WUFIGraph doesn´t work
Hi Crna,
the wfd-file should appear in your folder after you save your calcualted project. If there is no wfd file in folder, something went wrong. Then you should not be able to see any results.
If you use Windows7 or Vista please change the Homedirectory of WUFI. It should not be located in C:\Program Files\... this will cause right problems...
Mhhh... I work with Windows XP.
I reformated my PC last week and still have no spreadsheet (excel, calc, ...).
Could that be the reason? Thanks for your help.
Crna
Crna
I recently installed OpenOffice and changed my Home Directory but I still can´t use WUFIGraph ...
By the way: My project folder contains a file of the type "WUFI®2D3-Results". May that be the .wfd-file?
Sebastian Boegl
Yes - the WUFI®2D3-Results file is the named .wfd extension.
Can you try to open this file in WufiGraph 2.5 (File -> Open WUFI result file)?
I can´t find a possibility to use WUFIGraph2.5.Can you try to open this file in WufiGraph 2.5 (File -> Open WUFI result file)?
I can´t open WUFI Graph at all. I haven´t only problems in opening my result files - I can´t open the "main screen" as well.
Neither via the "WUFIGraph"-button, nor via "View -> WUFIGraph", nor via "Explorer -> C:\-> etc".
WUFI2DMotion on the other hand works perfectly well.
Or did I missunderstand you?
Sebastian Boegl
Hi Crna,
the latest version of WUFIGraph is 2.5. Can you please check your executable if it is up to date?
If you could attach the following file to your answer I can track down the error: %APPDATA%\WUFI\WUFIGraph\log.txt
Sebastian
Sebastian
Actually I can´t find any file with the name of WUFIGraph in my WUFI-folder...
I only got several files with WUFI2D-3.3...
Sebastian Boegl
WufiGraph is located in the Tools folder next to the installed WUFI2D folder.
If you could not find this file WufiGraph is not installed. Check if you unziped all files from the WUFI2D installation package to one folder (for example your desktop) and then please reinstall it.
Hey. I reinstalled it and now it works.
Thanks for your help!
