Batch file for export of single project with multiple cases
Bernd
Post by Bernd »
Hello Everybody
My typical projects feature a basic scenery calculated for various parameters. Therefore I create a single project file with multiple cases derived from the basic scenery instead of separate files for every case.
As shown below I've tried to use a batch file to export ascii files of every case within the project. By the way the number of data columns to export differs from case to case.
Code: Select all
"C:\Program Files (x86)\IBP-Software\WUFI5\WUFI.exe" "E:\project_001.W5P" -c -v111111111111
"C:\Program Files (x86)\IBP-Software\WUFI5\WUFI.exe" "E:\project_001.W5P" -c -v1111111111111111
But the batch file results in repeated simulation and export of the case last saved.
Can anyone help me with this problem, please?
Thanks in advance!
Re: Batch file for export of single project with multiple ca
Hello Bernd,
for the batch the parameters are defined as followed:
-c Berechnung der aktuellen Variante starten
-C Berechnung aller Varianten starten
For -c "actual case" means the one last saved. So if you call the batch three times for the same case with that parameter, it will use three times the same case.
You have to rebuild your case so that the positions to export are all the same in every case. Then use -C with -v. In WUFI 5.1 that is not working, but in WUFI 5.2 it works.
I send you PM...
