Interzone ventilation - Wufi Plus
Fabien Coydon
Post by Fabien Coydon »
I am trying to simulate an exhaust ventilation with moisture control in a single dwelling.
Since I would like precize results, I would like to have one zone per room in the dwelling.
Fresh air comes into the sleeping rooms and living room and exhaust air is sucked up from the kitchen and bathroom.
I need to use the interzone ventilation, but for interzone, there is no possibility to enter a moisture control.
The only solution I see is to simulate the kitchen and bathrooms with a mechanical ventilation with relative humidity control, to put the results (air flow) in a file and to use this file as input data for the interzone ventilation in a second simulation. I will probably need some iterations to obtain a correct result, so I'm afraid, this will cost me a very long time...
Does anyone have a better idea?
Thanks a lot in advance
Fabien
