Exporting Results from WUFI Plus
cjschumacher
Post by cjschumacher »
The WUFI-wiki (http://www.wufi-wiki.com/mediawiki/inde ... lus:Output) suggests that users can export results from WUFI Plus:
"The third possibility is to export the needed results as ASCII to Excel or file. All calculated courses and graph curves can be selected. There is also the possibility to chose the time interval."
The image on the wiki shows an "Export" tab on the results form but I don't see any "Export" tab on my copy of WUFI Plus. Is this only available in certain copies of the software? Do I have to do something to enable the export?
Re: Exporting Results from WUFI Plus
Post by mpazold »
The Report: Data & Results Tab should be available for the Case, for a Zone and for a Component (in the project treeview).
The "Export" Button is only in the "Case - Report: Data & Results - Tab" and if you retain calculation results of an component, there too.
If you are in the "zone - Report", there is no export tab, at the moment. But you can export all zone results under the case - report.
It this not helps, pleas tell me your WUFI Plus Version number (2.5.1.0?)
cjschumacher
Thanks, mpazold. I was looking for it at the Zone level. I see it now at the Case level. :D
