I'm trying to model SBS Modified Roofing. I cannot find it in the database. Do you have any suggestions?
Thanks,
Kerry
SBS Modified Roof Membrane
Re: SBS Modified Roof Membrane
Hello Kerry,
for a roofing felt it is usually enough to model the water diffusion resistance. So just use one from the database and change the value according to the producers information. For the calcualtion you also should set the short wave absorption according to the felt surface. The long wave emission is usually about 0.9. Further you can switch off the rain.
